The message you are trying to access is permanently deleted.
I tried out a demo of this one time and it was awesome. I think it can be configured to report the cost of your part.
In Reply to Chris Rees:
Is anyone using ModelCheck to determine rough order of magnitude cost?
Or better know of a 3rd party vendor that has a bolt on solution?
I would think that you can get model check to report the # holes,
material, X, Y, Z envelope dimensions and the part volume to get an idea
of how much material is removed. With those parameters and maybe a few
others you could have an algorithm that determined a rough order of
magnitude for part cost.
Chris
This communication, including any attachments, consists of non-public
information that is intended solely for use of the individual or entity
to which it is addressed. It is a confidential communication that may
contain information that is proprietary, privileged, export-controlled
and/or exempt from disclosure under applicable U.S. and non-U.S. law.
If the reader is not the intended recipient, or agent responsible for
delivering the message to the intended recipient, please notify the
sender immediately by reply e-mail and delete the communication,
including any attachments, from your system without saving any
information or making any physical copies. Unauthorized use,
dissemination, distribution or copying of this communication, including
any attachments, is strictly prohibited.
