Greetings,
I have created a variable section sweep which follows a datum curve and is normal to the trajectory.
The sketch is basically a rectangle. As the rectangle goes up around the curve, it begins to bank like a roller coaster track.
I want the rectangle bottom to always stay parallel to the ground.
I cannot for the life of me figure out how to enable this. My section has a constraint to be horizontal.
The only thing I can think of is to draw several parallel sweeps and connect them with blends.
Thanks guys! Selecting Section plane control> Normal To Projection did the trick!
