Variable Thread form... Helix
kgriffith
Hi All....
I need to createcustomthread form..I was trying to use theHelix command.I need to vary the angle of thread form on one side approximately 2 degrees per revolution. (see attachment)I thought it could be done using Sketcher relations or a Datum Graph feature, But haven't come up with a solution or formula yet...anyone have any Ideas orsuggestions? Any help is appreciated... Thanks
Ken
1 REPLY 1
RandyJones
20-Turquoise
(To:kgriffith)
On 04/04/13 13:27, ken griffith wrote:
> Hi All....
> I need to create custom thread form.. I was trying to use the Helix command. I need to vary the angle of thread form on one side approximately 2 degrees per revolution. (see attachment) I thought it could be done using Sketcher relations or a Datum Graph feature, But haven't come up with a
> solution or formula yet...anyone have any Ideas or suggestions?
I would do the following:
1. create a datum curve, by equation, using cylindrical coordinates, that represents the inner profile of the thread
2. create a variable section sweep (to cut the thread profile) using the datum curve as the trajectory
      * may have to create a straight curve down the center for a reference curve
      * define the variable section sweep section using the trajpar parameter to control the angle. Search ptc knowledge base for trajpar and you will get several "how to's"
> Ken
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
