View appears blocked
BenLoosli
Didn't get much response from the viz topic, so trying again here. Got no response from the Community.
In CreoView 2.0 publishing, we are publishing a WF4 drawing that has shaded views on sheet 2. One of the views has what appears to be a masking of the geometry from view bounds of the other view. Item callouts in that portion of the drawing show fine, just some part details are blocked out. I opened the part in WF4 and the view bound is NOT covering the other view in the area blocked on the drawing. We are publishing to PDF. Has anyone seen similar behavior before?
3 REPLIES 3
llie
(To:BenLoosli)
Ben,
What version of Pro/E doe you have loaded on your CAD Worker machine? I
think it is a WF4/Creo View 2 thing. We saw that happening in our testing a
couple years ago and were told to upgrade the CAD Worker.
Lance Lie
Sr. Info Sys Technologist II
Global Business Services - Information Technology
Raytheon Company
714-446-2806 (office)
714-402-7858 (cell)
1801 Hughes Way
Fullerton, CA 92833 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
This is a known issue. Fixed in CV3. As a matter of fact, if memory serves, there's no need to republish, it is apparently the rendering engine or some such.
Brian Krieger
Peterbilt Motors
Yes I have seen that in WF5 too and never found a good solution so had to move views around and export to PDF to see if the masking was fixed or not and repeat as needed.
Didn't like that you couldn't shade a perspective view either, but am now back on WF4, so have no idea if the PDF issue is fixed or if you can now shade a perspective in Creo.
Good Luck,
Mark A. Peterson
Design Engineer
Varel International
