Good Morning ProE/Creo experts,
Is there an easy way to determine the volume of a cavity in an assembly? I could create a dummy model of the cavity and determine the volume of the dummy but it is a fairly complex shape and I am hoping there is a more efficient way of accomplishing this task.
WF 4.0, M120
TIA
Jim Majewski
Assemble a cube which overlaps the extents of the cavity x, y and z
Edit > Component Operations > Cut Out
Pick the cube to be cut
Ctrl pick the components which create the cavity to cut the cube.
Find the volume of the cut cube part
Sean
