Creo3.0 M030
Anyone come across this?
Attached model contains 2 volume regions.
Volume Region 1 works fine and has an external surface.
If I try and bury it (resume extrude 2) the volume region fails.
Volume Region 2 is created in the middle (no external surfaces). It fails.
I have yet to check in earlier versions.
However, I can bury it by assembling another component to cover the exposed face.
Is this behaviour correct?
Completely buried volume regions don't work in Wildfire4.0 M150 either.
'Could not intersect part with feature'
