Volume
ptc-2192405
Volume
hello,
i'm trying to rough using volume, but the tool is invading (within green square in picture attached)
the only way i know is to change the model but i don't want to do that because i will have a few problems, i would like to know if anybody knows another way for the nc sequence recognize a surface or anything else as part.
Hi bambi!
Try to add the fixture surfaces as check surfaces...or use a mill window
to limit the tool so that it won't cross the boundaries you set...
Kct de agulha!
Daniel
i got the solution for my problem, i use idea from Nyguen and Daniel,
attached there's the solution, maybe can help someone who has the same problem,
thanks,
