WARNING: cannot set system parameter for CopyGeom feature
CHG
3-Newcomer
3-Newcomer
I don't want to see the warning "Cannot set system parameter for CopyGeom function". This is annoying and has no added value.
How can I set this warning to no longer appear?
Workaround: See CS418177, needs to be done every time when changes are made,
What we use it for: We use skeletons with Publish Geometries, they are published to several sub skeletons and parts Which causes each time a lot of warnings when changes are made to the skeletons
Impact on us:We have to deliver our models clean and clear without warnings Each time we have to edit the External Copy Geometry when the warning appears So it is time consuming when you have a lot of models where this occur
2 REPLIES 2
CHG
3-Newcomer
3-Newcomer
(To:CHG)
Please help to solve this issue
Hi @CH_10156510,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
