WELD PROCESS PARAMETERS
Felipe.Morais
I need to create a list similar to the BOM but with the asm welds. I need the weld information (SEQ_ID, TYPE) and I need the welding process intervals linked to that weld. I have some parameters in the weld process but i dont know how acess this parameters in the drw. I add some photos.
Using the example of the photos iset the weld process 3, in the weld process have parameters about current, tension and gas. So i need a table like this:
SEQ_ID   TYPE      WELD_PROCESS   CURRET(A)    TENSION(V)     GAS
1               FILLET   PROG3                     230                  26                      CO2
2              FILLET   PROG2                     210                   22                      ATAL25
I am using CREO 8. Thanks!!
0 REPLIES 0
