We're working on our config files for WF 5. We're currently on WF 2, so we have a lot to do, which is fine, because we probably needed a good house cleaning anyway.
We have this very specific need inside of drawing, that I cannot replicate in WF5, that has worked up to this point.
I want to start on ANY sheet in a drawing. Then, use the "Go To Sheet" command to go to Sheet 1. Once there, I want to go to the PREVIOUS sheet, and then export whatever is on that sheet to a DXF file. We have ALL of our drawings setup such that the final sheet, no matter how many sheets there are in a drawing, is always the sheet that contains the DXF model. Some drawings have 2 sheets, and some have 5, and we're everywhere in between those numbers, so I can't just say, "Go to sheet 3".
There has always been a "Go To Sheet" under view, and it's not there anymore. I have figured out that I can click on the SHEET 2 0F 5, in the bottom area of the drawing, and get to the GO TO SHEET 1, and then PREV, but I cannot seem to make that work reliably, because our sheet sizes are not always the same, and things move around, or so it seems. I've also noticed that the same things don't work from session to session. I can get it working, and then with a new drawing, it doesn't, and sometimes, it works in session, but doesn't work after a restart of the session. So something is flaky in my mapkey.
Did they move this command to some place that I can't find, or am I missing something totally obvious here???
Darrin Hiebert
Excel Industries, Inc.
