WF3 Export PDF Settings
llie
Has anyone been able to customize the Export PDF Settings dialog box that opens with the PTC Provided icon, Save as PDF?
I was wondering if an Admin could restrict certain options or maybe remove it and replace it with a one that creates searchable PDF. The icon is the only way get the searchable text option.
You can create a mapkey off of the icon, but you still need the icon to run the mapkey.
Any suggestions would be appreciated.
Lance
2 REPLIES 2
VladimirPalffy
(To:llie)
Hello
If you have defined mapkey, you do not need the icon. You can run mapkey typing with keyboard (Key Sequence).
I use many of mapkey typing with keyboard and I have few icons from mapkey - It is most effective when you combined this simplification
Vladimir
Best Regards,
Vladimir Palffy
DHLewis
(To:llie)
Lance,
As the versions have advanced there are more and more Config.pro/sup options that control the PDF output. There are only very few options available in WF3. If you search for options "pdf_*" you will find them in your options.
What exactly are you looking to control?
David.
