I am looking for some help with installing the Feature Recognition tool with WF4 M150. I downloaded the program from PTC and followed the instructions. When I startup pro I keep getting the following error message: feat_recgn_dll failed to start.
Thanks in advance
Ok I found the problem. First of all want to that everyone that sent me suggestions. After further investigation I found that I had the 32 bit of pro/e installed and not the 64 bit. I was trying to install the FRT for the 64bit version of pro on a 32 bit install.
Solution: Installed the 64 bit of pro and everything works great.
Again thanks for all the supplied their input.
