WF4 MDX animation of a "Roll-Up Window Blind"
jvisin
I'm trying to simulate/animate a mechanism that represents something simular to a fabric roll-up window blind. I've attached a small video that show my approach using a cam follower and what you will see is that the connection seams to jump off the surface at one point over to another. If I could get this to work I could attach slats to represent the fabric. Ideally, if I could use a surface some how to represent the fabric... this would be better. If someone has a better approach (which I'm sure's one), I would appreciate any/all help.
Dan_Harlan
(To:jvisin)
Try using a slot rather than a cam. I've found them more stable whgen I don't need lift off or dynamics.
4 REPLIES 4
Dan_Harlan
(To:jvisin)
Something like this? The spiral datum curve is the Ground body; the "lever" is the Motor; and the puck uses 2 Slot constraints and a Planar constraint. This just happened to be what I was working on this post: MDX Linked Chain Model ... the video in the link will help with defining the Slot.
Video Link : 3986
Arrrgggg... the forum kept spitting out the upload.
Thanks A Lot... the 3 constraints did it...
Thanks... the slot work fine !!!
