WF4 ModelCheck Date Stamp
TerryMcFall
Anybody else experiencing problems w/WF4 not updating the MODEL_CHECK date stamp parameter? We were ready to roll WF4 out to users but this will certainly delay things if not resolved.
We're running IL3.4 M062 and have seen this in WF4 M050 & M130... even tested it outside IL (on disk) w/same problem.
Thanks in advance for any assistance.
-Ter
Terrence (Terry) McFall
CAD Systems Administrator
Varian Medical Systems
911 Hansen Way
Palo Alto, CA 94304
650-424-6039 desk
650-799-0179 cell
We ran into that problem with M040 and M100 WF4. Check to see if the correct check files are even being used.My condition filehad "If clause" for MODELNAME EQ VL-8* *with asterisks) combined with GROUPNAME. ModelCheck would NOT use the check, start and condition files in the "If clause". I had to delete those statements and create a .bat file for our Librarian Groupto use a different set of ModelCheck files/location. PTC was able to duplicate the problem and the fix is expected in build M160. By the way, in M100, you can add the ModelCheck directory to your config.pro.
