WF4 and Simplified Rep bug
MGortner
All,
Has anyone observed a bug where a global interference check ignores your
simplified representative setting?
Here is what happens - if I open an assembly simp rep (without other
parts in session), the global interf check works as it should. But if I
switch to the master rep (thus putting all parts in session) and then
switch back to the simplified rep, the global interf mistakenly checks
for interference between all parts, even those that are excluded from
the current simp rep.
Matt
Matt Gortner | Mechanical Engineer
CHASEDESIGN, LLC
1400 East Genesee Street | Skaneateles N.Y. 13152
315.685.1000 (p) | 315.685.5021 (f) | www.chasedesign.net
Quick follow up - I opened a call and PTC could re-create the bug they
did not have a fix. Hopefully they'll fix it in the future. I've also
seen this issue is numerous assemblies. Perhaps the problem is caused
by assembled parts (or start parts) created in earlier versions of PROE.
-Matt
CHASEDESIGN, LLC
