I couldn't find it either initially. What is even more confusing is that the WF5 help system still shows that sketched datum points are created using the WF4 and lower method.
However, if you create a new datum sketch and on the point flyout menu you click "Geometry Point" as opposed to "Point" it will create the sketched datum points as we all remembered it.
Steve
In Reply to Paul Gress:
Hi all,
On WF4 when I needed to create datum points there was one selection to
sketch it in. Now I'm using WF5 and I can't find it. Was it removed or
moved and I cant find it?
I knew when I moved to WF5 it would bite me.
Paul
Paul Gress
President
Rad Electronics Inc.
3122 Expressway Drive South
Islandia, NY 11749
(631) 243-7707
(631) 243-7708 Fax
www.rad-electronics.com
