We adopted WF5 last week and I have had nothing but complaints from the user community regarding the increased amount of clicks to complete tasks. They have also found multiple problems using the show annotations tool. Does anyoneone have similar experiences or found ways to reduce the number of clicks in WF5 detailing.
Jason
When you post a question of this nature it is important to include all the infomation ?
what problems are they having ? a little more detail, for example users have experienced ..... details
What is the datecode of WF5
what graphics card do you have
and some basic computer information is generally helpfull
Dave McClinton
Mckesson Automation
We areon WF5 M030. I am usure how the graphics card comes into play.
The question is regarding the actual workflow of the software with the ribbon interface. The number of clicks to complete everyday tasks as increased due to the new UI.
With regards to showing model annotations, there are plenty of problems that are due to the functionality;
These are just a few examples; I was just trying to get a feel for how the rest of the community was doing with the ribbon UI.
Rui,
You have some good points and we have learned these options.
We have found the following faults after investigating your comments:
Even if you select something that is not "in order" with the current tab using the Alt Key, you can't do anything with it until you switch tabs.
Usually only critical items are renamed...to rename every dimension is unrealistic.
Ihave found theerased dimensions are in the model tree. To find the correct dimension, you have to know what view the dimension happens to be assigned to and then you have to find the dimension which could take anywhere from 2 minutes to 20 minutes depending on the complexity of the model.
A few items that were brought up (not only in this message):
In order to click on items that are "out of order" with the current TAB, use the ALT key.
The "d123" that shows in the model tree is the same parameter name assigned to the dimension in particular or the annotation in general. Change it and it will change in the model tree.
Erased dimensions are still available in the model tree. Just RMB, UNERASE.
On 05.04.
I too do not like the ribbon for the same reasons already mentioned.
Does it have any advantage over prior releases?
Does anyone like it?
Gerry
Rui,
Thank you for pointing out that you can edit dimension values while not in the annotate tab.I was not aware of this possibility...are there any other things that you know of that can be done when "out of tab"?
Jason
To Jason
you may be exaggerating on purpose, but to say you can't do "anything" with something until the correct tab is selected is inaccurate. In the Layout tab, you can reposition dimensions, edit a value, etc. In the Annotate tab, you can select views and reposition those. Maybe I'm privileged that normally I place (most) views, then dimension and hardly ever need to go back and forth. I confess that I don't do many 2D's, and will iterate that I can understand all your (and others') points. Was just pointing out some things that maybe not everyone knew about.
As for dimension names, renaming was an example, but someone (sorry don't remember who) mentioned them as if he/she didn't know where those numbers came from.
Rui
On 06.04.
Need to spend more time on it to see if there are any contextual tool
bars and see if there are any gallery previews when hovering the mouse
over a selection.
Does anyone know if there is a keyboard shortcut to switch tabs?
Jim,
There is no pop-up toolbar when hovering, you can however RMB after selecting something to get a contextual menu.
I created mapkeys to switch tabs and minimize / maximize the ribbon to gain screen space. I'm not sure how much they are getting used yet.
