WF5 - Drawing Mode Show/Erase
CBenner
8-Gravel
Anyone using WF5 have an issue with the show/erase? Specifically, if you erase something... you cannot get it back? I erased some Axes from an polder drawing in order to clean things up for a bit... intending to "show" them again. Now the show tool doesn't recognize them. Right clicking on the axis in the model tree does no good either. Same is true for dimensions that I erased. It's like they don't exist anymore, even though they show up in the part model.
Chris Benner
Autodesk ® Expert Elite
5 REPLIES 5
Never mind!!! Once again, PTC in it's infinite wisdom HID the unerase command!
Chris Benner
Right click in the drawing tree not the model tree, this will show the unerase command.
Yes, I found it... but why bury it there and not tell anyone. With WF4, show/erase would work on items that had been erased before... why take that away... did this really simplify things in any way?
Chris Benner
PTC: In Wildfire 5.0 it is not possible to show cosmetic threads individually once they are erased.
Cool
A menu mapper might come in handy.
