WF5 Problem with new tool motion interface
ptc-2958244
We have loaded up the first version of WF5 just before xmas and I have been switching between WF4 & WF5 until we sorted out the issues with files But now I have to start working with WF5 fulltime. I have come accross two issues with the new tool motion interface. Sequences which have been done in WF4 are still using the legacy customise cut interface, which is working fine. But the new tool motion interface which is called when a new sequence is called hhas bugs When trying to insert a GOTO POINT the selection window won't lock onto any point on the tool motion. I can't add any GOTO POINTS The second issue is that the GO HOME command is picking the right head home point ( we are machining using a twin axis vertical borer- two turret ) The old interface is still working fine. Is there an option to turn off the new interface and use the old one, or does anyone have a solution to these issues Thanks
0 REPLIES 0
