TABLE PATTERN
FarrukhRizvi
TABLE PATTERN
Hi guys, i have done a file with table pattern quite some time ago. Now i want to edit it for some modifications but i am not able to see table. In other words, table spreadsheet does not pop-up to make modifications. Everthing is fine, i mean regen and references. Does anybody knows what the problem is. Thanks in advance. Farrukh
Hello, did you check your "part_table_editor" option in config.pro ? Does it work if you create a new table-driven pattern?
Hello I did check, everthing is OK. when i restart pro-e, I am able to edit the table but only for first time. Second time table does not appear when i click on edit. I think there is some bug in this assembly file, all other files are OK. I can edit table as many time as i want. I am scratching my head and looking around for solution.
Have you tried using Alt+Esc to cycle through all open windows? Sometimes a pop-up window can appear behind the main Pro/E window - this happens to me with DXF export most times.
