WHERE SHOULD I DECLARE THE LOCATION OF START UP PARTS
ptc-2897425
I am importing data from step format but i want pro e to use my start up part while importing data from step format. how can i achive this, iam guessing that i have to declare my start up Part and start up asm location so that when ever pro/e tries to create a part or asm it will use these start up files. can any one help me on this. I am a old pro/e user forgot most of the stuff in using proe. Thanks in advance Ramesh
You can create a new part,than insert--> shared date-->from file! you should set up files what you want from template.
First do you need set templates for Start Parts in configuration file (configuration_option and path_to_start_part):
- for solid part:
template_solidpart D:\start_models\start_part.prt
- for sheetmetal part:
template_sheetmetalpart D:\start_models\start_smtpart.prt
- for assembly:
template_designasm D:\start_models\start_asm.asm
... then you can open your data: see video
Video Link : 2945
Vladimir
Best Regards,
Vladimir Palffy
