Weblink - How to get Activate Model in Assembly
Shu-FanWang
2-Explorer
Hi, all
I have trying to assemble components into subassembly which had been activated,
but just can't find any way to get the Activate subassembly model.
model.currentmodel only can get root assembly.
Is it possible to dothat in weblink?
Any advisewill be fully appreciate
No ? you cannot do this with Weblink.
It is not possible to set the active model and you are not able to find out
if the active model differs from the current model being displayed in the
current window.
Andreas
Thanks for the reply~ Andreas
Itry to use pfcselect instead, let users to point out the target subassembly.
It works well as below;
var selopts = new ActiveXObject("pfc.pfcSelectionOptions").Create("prt_or_asm");
var sels = session.Select(selopts, null);
var sel = sels.Item(0);
var model = sel.SelModel;
Pro/E will pop up a Select message window while session.Select(); (as attachment)
Is that possible to change the text "Select -2147483648 items" at will?
Shu-Fan
There is a MaxNumSels property on the pfcSelectionOptions class. See the
APIWizard.
/Bjarne
Shu-Fan Wang <->
23-03-2011 13:48
Please respond to
Shu-Fan Wang <->
To
cc
Subject
[proecus] - RE: AW: Weblink - How to get Activate Model in Assembly
I try to use pfcselect instead, let users to point out the target
subassembly.
Thanks for the reply,
It works as below,
sels.MaxNumSels = 1;
The text become "Select 1 items".
~Shu-Fan
