I am using wildfire 3. I have created some welds on my assembly. I then detailed my assembly. I hit the show and erase button. The weld annotations show up fine except for a couple of things. After i insert each weld pro-e keeps a sequntial number. I need know how to get rid of this. Also I need to know how to put a flush symbol with a grind. As it is I right now i right click on the symbol and select properties it says the symbol cannot be modified.
