Typically,
Thus, there are two cam diagrams in my process:
I believe there might be a better method for creating a barrel cam model and its associated drawings.
I would appreciate it if you could share your experience,
thank you~!
This seems to come up regularly on here. Like this discussion:
It is a shape that is relatively straightforward to create in the real world, but very difficult to model. I would imagine this makes it very difficult for anyone to create 3D printed models for this type of component.
I've had success making quarter turn fasteners (DZUS) by defining curves that can be used to build surfaces that cut the slot, but that's a much simpler bit of geometry than a cam profile.
