When adding Integer 1 in unattached note in creo drawing, its printing as I, attached the Image.
The same is working in my colleague's creo.
Any configuration need to be done?
Creo Version : 9.0.3
This isn't an error, it is the result when you are using the default "font" (that is its name) for text. This default font is pretty terrible, in that a capital "I", lower case "l" and the number "1" all look like what you have in your image.
I use "isofont" for all of my text and it has distinct representations of all three of these characters.
To specify this for drawings I have a setting in my "drwsetup.dtl" file that says:
default_annotation_font isofont.ndx
Unfortunately, if there is already text defined in a drawing, this setting won't affect it. It only affects new stuff.
Alternatively you can replace the default font with a modified version and that will effect everything but it will also need to be copied to all machines (including a publisher) that are running Creo.
There is modified copy posted in this thread:
https://community.ptc.com/t5/3D-Part-Assembly-Design/FONT/td-p/416262
PTC's official position is that they recommend that everyone switch to a truetype font like Arial:
We switched our default font to ISOFONT a few years ago to avoid that issue.
We have not made the switch to TrueType fonts, yet.
Using a modified copy of font leads to issues, so stated. You need to copy it to all of your computers that run Creo. You also will have issues if you send a file to someone who does not have your modified file installed as the text will revert back to the OOTB font look.
Hello @TDT,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
