When changing a parameter in a table, only the parameters value should be modifiable
BHepler
2-Explorer
This issue is especially a problem in a drawing title block.  It is currently possible to double click on a parameter driven value and change it in the table.  Instead of updating the parameter value, the parameter (i.e.  &revision or &scale) is overwritten.  This displays what was typed but breaks the link to the parameter.  Currently the table cell needs to be selected, then Edit needs to be selected from the pop-up menu so the parameter is updated but not replaced.
The case number for this issue is C13212082.
Dale_Rosema
(To:BHepler)
BHepler
You may want to vote on your own idea......
BenLoosli
(To:BHepler)
Better yet would be to lock all table cells that are parameter driven so they can only be changed from Tools-Parameters.
BHepler
2-Explorer
(To:BHepler)
The solution Ben has proposed is great.
I don't think this is really an enhancement request.  I am not asking for new functionality, I would like to have a gap in the current software resolved.   When modifying a table or anything else in Creo, the different options for making a modification should produce the same result.
I think there should be a different process for making the current software function consistently, versus requesting new functionality or improvements to existing functionality.
