When using creo parametric 2.0 on a laptop, how do you get a 3D view of the drawings?
nfernando
2 REPLIES 2
in Drawing mode you cannot rotate drawing sheet. But you can place 3D view of model in the drawing.
MH
Martin Hanák
Hi Nilthara,
In the model there are some default orientations set.  In the drawing, create a General View and select the one that has the 3D orientation, to create a 3D drawing view.
Amit
