Windchill Retrieval
WF_10971917
6-Contributor
Windchill Retrieval
Greetings,
Not sure if this is a Windcill or CAD file or network issue. Has anyone ever had issues opening files in Windchill but another person does not? I have cleared cache, cleared workspace, reset Windchill and still not able to open.
One thing to note: We work on different networks that I guess tap into a shared Windchill. This may have something to do with it? I have seen problems with syncing checked in/checked out files.
If so, what fixes the problem?
Wayne
1 REPLY 1
StephenW
(To:WF_10971917)
I would try exporting the file(s) to the hard drive of the computer that doesn't open it, just to verify it's not a creo issue.
Whenever someone asks me about issues like this, always my start question is, New workspace or ? If I have problems like this, I always start a new workspace and retry. Next step to clear the cache.  From your description, it looks like you've done that.
Then I move to the exporting to hard drive, not as a solution, but a test to see if there is a local setting on creo that is causing the opening issue. I assume that if I can open it from the hard drive and not from windchill, that it is a windchill problem, or conversely, if I still can't open, it's a creo problem.
