I am working on something that I need creo and excel open simultaneusly, so I put creo on half the screen, and excel on the other half. I can open parts fine, but if I open a drawing, the creo window resizes to take up almost all of the screen. Is there a way to stop this from happening?
thanks
Hi Josh,
I searched for the related config options "open_window_maximized", "windows_scale" and "reserved_menu_space"
Try to set these config options with required values.
Sachin Mahajan
I use AutoIT to handle this situation.
It's a free programming language that can look at window titles and react based on them, such as (not exact, but close enough to give the idea)
while(1) ; forever
$size_creo = WinGetPos("Creo Active")
$size_excel = WingetPos("Excel")
IF WinActive("Creo Active") and $size[2] <> right_width and $size[0] <> left_edge then
WinMove("Creo Active", new size, loc)
WinMove("Excel", new size, loc)
EndIf
wend
Leave this running when you want the split screen and stop it when you don't.
