How can I measure wire length between 2 location points? I am able to measure length of a segment but not between 2 location points of my choosing. I'm using Creo 4.0 cabling module.
Thank you.
After you've measured the length of your cable, if you hold ctrl and select the two locations you want to measure between, the length will be displayed in the message log.
Thank you so much....this worked.
