Wrong inertia (???)
bopeti
Wrong inertia (???)
Hi all,
It seems that the marked 2-2 inertia values have been replaced in every case. Iyy and Izz.
(File/Prepair/Model Prop/Mass Prop <--> Analysis/Mass Prop)
Is it normal?
Thank you for the answers.
MartinHanak
(To:bopeti)
  • in left dialog box you use default CSYS
  • in right dialog box you use non-default CSYS named CSYS
I think the above two CSYS have y and z axes pointing in different directions.
Martin Hanák
MartinHanak
(To:bopeti)
Martin Hanák
bopeti
(To:MartinHanak)
Yes, you are right, thank you
