Yellow light depending on what I regenerate?
jtruitt
7-Bedrock
I know yellow regen issues aren't always straight forward but I feel like mine has got to be solvable. I have a top level assembly where I have a subassembly with several parts in it. In the top level assembly I'm trying to make a cut with a plane to the parts in the subassembly but every time I do this the parts open back up yellow. The top level assembly and parts are green if I remove the assembly cut. If I make the cut during the session the parts and top level are green but upon reopening the top level assembly is yellow now. This is what is frustrating, I can regen the yellow top level to green and make the parts go green, save it, and it opens yellow BUT if I go to the yellow parts and instead only regen them and then save them (not the top level) the assembly will open green next time and act correctly. Am I in a loop that can't be corrected? I don't want to have to remember to regen specific parts to make the assembly green every time.
0 REPLIES 0
