I recently got a new computer and had to reload Pro/E (Wildfire 5.0) onto the new machine. I noticed that I can no longer use the mouse wheel alone to zoom in and out as I was able to do before. Is there a setting that I can change to get this feature back?
If your new computer is Windows 10, How to make scroll wheel zoom work in Windows 10 with Creo Parametric.
If it's not windows 10, you probably just need to set the mouse wheel settings WHEEL/MIDDLE MOUSE or something similar on your mouse manager
Worked perfectly! Thanks!
Dont' forget to mark Stephen's answer as correct.
