Does anyone know a way to read a Solid Edge.dft file in Creo 2.0. I have a client who gave me this file and wants me to get model together for 3d printing. I need to know if there is any way to read this file type in Creo 2.0
It is possible to convert the Solid Edge file to a neutral format, as STEP and then, read it in Creo.
This type of conversion is possible with CrossManager : http://www.datakit.com/cad-convertors/solid-edge-to-step/14-7-0.html
A Solid Edge .dft file is 2D only. Ask your customer for a .stp/.iges/.x_t file of his .par file
Referring to the following article:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS127522&lang=en
Creo Parametric 3.0 can import native Solid Edge Part (*.par) and Assembly (*.asm) files
support import of Solid Edge version 18.0 - ST4
You can use free SolidEdge 2D to converting your file to dwg or dxf
https://www.plm.automation.siemens.com/en_us/products/velocity/solidedge/free2d/index.shtml
