user should have ability to replace/reselect failed references in remove feature like in this example:
current functionality is very limited here!
User can only delete wrong references or all...
Standard selection with <SHIFT> (up to boundary) should be accesible here 🙏
Ideas for enhancements or changes to Creo should be submitted here:
Creo Parametric Ideas - PTC Community
thanks I'll try to post it there
