asm_mbr_DESCRIPTION value
MikeMessenger
Is it possible to change the value of the Intralink parameter "asm_mbr_DESCRIPTION"? I'm using this in a repeat region BOM table, but the Intralink changes aren't being passed onto the drawing. Thanks Mike
Did you check the parameter value in the part? (open your part, then Tools>Parameters)
This parameter is not listed in the part. Any thoughts?
I probbly missed something, but I don't understand how this parameter can be used in your repeat region if it doesn't exist in the part... I don't use Pro/Intralink, but with Windchill there are some Windchill parameters called "ptc_wm_.......". The parmeter you are talking about seems to be a user-defined parameter, which can be manually created in your part. asm.mbr.DESIGNATION is a report symbol of your repeat region which calls the user-defined parameter "DESIGNATION", isn't it?
SylvainA.
(To:SylvainA.)
The "a" key of my keyboard seems to be sick
anonymous wrote:
....probably.... ....parameter....
