Is there any way to assemble same part multiple times like 50 some instances, just like screws etc with one click.
I know there is repeat option in creo parametric but I want some different
Is there any other option?
Four, that I know of:
1 - Repeat
2 - Pattern (table, point, reference, etc.)
3 - Component interface + copy, paste....similar to repeat. Or you can use auto place to find all similar interfaces.
4 - Specific to screws and bolt+nut+washers sets, you can assembly them quickly and easily using the AFX module. If you don't have the AFX extension you will be limited to the "free" version (Creo 2.0) that can only do something like 8 or 10 screws at once.
Here's a quick video showing auto place with component interface:
