Hello everyone,
We just upgraded to CREO 11 from CREO 7. Axis are showing up as solid lines in models in 11 but show as center line 7. I've been looking for a config setting or something to fix it with no luck. Gets to be a mess with large parts. They display better in drawings, you can zoom in and see it's a center line at least. They show up correctly when printed.
Any suggestions?
Remove all the setups and try in out of the box creo, just to trouble shoot if it is something specific to your setup. That's always a good first step.
Is this an imported model (STP, IGES or similar)? I have Creo 11 and axis show as centerline.
Nope it's CREO parts. My co-workers CREO 11 displays correctly. I'm stumped!
Is it possible that there are multiple axis in this location that are really close together but not perfectly aligned? I can achieve what looks like a solid line using two features that are offset by 0.001mm
