backward compatability
CharlieGraham
To All,
Is it possible to open an object, part and or drawing, created in Pro/E Windfire 5.0 in version 4.0. And if so how?
Thanks for the help,
Charlie
10 REPLIES 10
Charlie,
You need to install the CGRI which can be found at;
Sorry,
as far as I know there is no possibility to open a WF5 file using WF4. The
only time I remember that such backward compatibility was offered by PTC was
for Pro/Engineer 19 vs. Pro/E 18.
Best Regards
Uriel Avron
Harmonic Systems Ltd.
On Mon, Jan 31, 2011 at 9:18 PM, Charlie Graham
<charles.graham@stryker.com>wrote:
> To All,
> Charlie
Hi Charlie
there are options and it is call GCRI see attached
cheers
Dave
Forgot to mention it does include WF5.0
GCRI has historically supported backward compatibility for the previous
two releases, i.e. WF 5 files would be able to be opened in WF 4 or WF
3.
A file has been sent to you via the YouSendIt <">http://www.yousendit.com>
File Delivery Service.
Download the file - GCRI_WF4.0_WF5.0.zip
<">https://www.yousendit.com/download/MzZGSXR3NDQ0b0JjR0E9PQ>
Your file will expire after 7 days or 100 downloads.
All,
I know that I have posted this video before but I think it is pertinent
to post again. This shows opening WF5.0 content in WF4.0. More content
on this subject can be found under the free downloads section on ptc.com
Iain
Rosemary,
GCRI supports backwards compatibility for parts and assemblies but not
drawings correct?
Why are drawings not supported?
Andrew Yap
Hi All,
If my memory serves me correct.
GCRI works if you do not want to go back to the higher rev of Pro/E.
You can bring Wildfire 5 into Wildfire 4 But when you save at the Wildfire 4
level
you lose the parametric features that were created in Wildfire 5 when you try to
open
it back up in Wildfire 5.
FYI
Don A
Can anyone verify that moving back and forth between new and old
versions is not possible?  I understood that it was capable of moving
back and forth between versions.
I can foresee situations where we might utilize CGRI, but not being able
to go back and forth would seriously limit its usefulness.  I'd like to
know if that's true before I rely on it.
Doug Schaefer
LinkedIn
The GCRI has the craft functionality to take features back to the newer
release. This enables you to transfer features added to the model in
WF3/WF4 as parametric features to the WF5 model.
So comlete parametric models can be sent back and forth between major
versions.
/Bjarne
Doug Schaefer <>
09-02-2011 20:57
Please respond to
Doug Schaefer <>
To
cc
Subject
[proecad] - RE: backward compatability
Can anyone verify that moving back and forth between new and old versions
is not possible?  I understood that it was capable of moving back and
to go back and forth would seriously limit its usefulness.  I’d like to
know if that’s true before I rely on it.
Doug Schaefer
