Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
is there any way to model a ball mechanism with constraints? How to you constrain the moving part to move inside a cone of 12 degrees ? (for example) of course the tip of the cone must be the datum point used of the ball mechanism.
thanks in advance
-- --------------------------- -nk/.
