cabling
ptc-4991971
cabling
I am new for Creo2-Cabling, Please help? would like to create Hose pipe for cables in assembly. I am expecting step by step procedure.
Create a spool and route the hose as per your requirement and pack the necessary wire in it...
Click on the "Spools" icon in the cabling ribbon, this will give a pop-up menu, click here on "Sheath."
Then use the help fuction and look for "To Create a Spool" this will give you the nessasary info to create your tube.
As far as the cabling/routing goes, you can also look up "Routing Techniques" & "Cabling Overview" in the help function (although some of the help function is still only for Creo 1).
