cannot add in Mass Analysis Feature in WF4.0 M080
ptc-154724
I am looking to add a mass analysis feature to my model, but cannot find how to do this in WF4.0 (build code M080). I was able too in WF2.0, but it appears the selection in the Analysis window that comes up is missing. I pick the icon for Analysis (or pick Insert/Model Datum/Analysis) and in the area for Type, Model Analysis is NOT there. It looks as though Model Analysis and Motion Analysis were taken off this. Any help on this would be appreciated. I have looked through the Knowledge Base, but cannot find the answer there for this. Dennis
The model analyses are now under Analysis>Model. Motion analysis is under Analysis.
Hello Dennis, were you able to produce what you wanted? Like Kevin was explaining WF4 changed a few locations for Datum Analysis features. Some are still located under the same tool as WF2, but others are now embedded with specific areas. Like Analysis > Model > Mass Properties > Change from Quick to Feature. This also works for other Analysis options like Analysis > Geometry > Point for example. Good luck, Joel
