chain dimensions
ptc-4448092
3-Newcomer
chain dimensions
Does anyone know if it is possible to make chain dimensions in creo 2?
Creo does a version of chain dimensioning. It is actually the ISO version of ordinate dimensioning.
I inserted a "dimension with common reference" then right clicked the dimension to convert to ordinate. Then select the zero value and right click and go to properties. Go to the display tab and change the style to ISO.
