I am making an assembly with particularly small components. I am using the slider function to set a position and I need it to be more accurate than the 3 sig figs that are standard. I tried going into the settings to change it to 5 sig figs but it still auto rounds to 3 sig figs. Is there a setting that I am missing or a work around I can use? I am using CREO parametric 7.0
Try config inch_grid_interval 0.00001
You may need to type in a value with 5 sig figs to get it to work during dragging.
Hi @KS_10732129,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
