Hello Proe users, I need help using datum points as control points for a boundary blend surface. I have created evenly spaced datum points (every 2,5 mm) on every curve along the axis of the bottle.
I have tried using all 3 points per curve as control points, a pair of points for every curve, etc.
I also created datum points on the vertexes of the patches of a first surface, then created a second surface and used those reference points as control points.
In the best case, the effect of these measures has been minor, almost unnoticeable. is there an ideal technique for locating the datum points to be used as control points?? in what other ways can I use datum points as control points to reduce the no. of patches on a surface?
regards, thanks in advance,
al.
