How to create a relation in a part in order to controle a fonction? I would like with a relation inhibit or not one fonction depending on a parameter Y/N
unfortunatelly I do not understand your question.
You can use translate.google.com web page to get english translation 🙂
How to create a formula that drives a function to enable or disable this function?
again ... unfortunatelly I do not understand your question.
Please provide some example.
I have a feeling that you are talking about FEATURES (not FUNCTIONS)
Anyway, in the relations of a part or assembly, you can make use of these internal FUNCTIONS:
Or, you can create your own function with a C Program:
If you want to drive FEATURES (turning them ON of OFF by suppressing them) in your model tree, then you must write a simple IF...THEN statement in PRO/Program:
HTH1
