creo 2 will not save as mirror part with features?
ptc-5388148
I am working on a series of molded parts and two of them are to be mirrors of each other. The overall design of the two has been established as the right side but I need to mirror it with it's features so that the two sides can be modified for a few different connector ports.
Using File>Save as>Mirror Part> it will not allow me to select 'Mirror geometry with features'.
"Can not mirror some features of this part" does come up, but there is no indication of which features are causing the 'problem.'
Any ideas of how to determine the feature(s)/culprit(s) causing this would be appreciated.
-Jack
Dale_Rosema
(To:ptc-5388148)
If there will be changes in the features that are mirrored down the road, becareful because there are stability issues when you update the original and are expecting those updates in the mirrored part.
And, welcome to the forum.
