creo_parametric_customization.ui
RogerEngee
7-Bedrock
I am facing opposite situation whereby i did not even export the .ui file, but yet when i tested by creating a new tab for my mapkeys, the newly added tab was still there after i closed the Creo 1.0 session and relaunched it.
I checked C:\Documents and Settings\ngr\Application Data\PTC\ProENGINEER\Wildfire\.wf\.Settings\creo_parametric_customization.ui and checked the details when it was last saved.. it was couple of weeks ago.. so I'm wondering where my ui customization settings are actually saved to..
Appreciate if anyone could share some thoughts..
Rdgs,
Engee
Check File - Help - System Information
Scroll down until you see Configuration files read.
Magnus, thanks for tip..
Yes it was stored in the same folder as WC cache.. i missed that
