creo3 rename parts in assembly mode?
danb
hi
We just moved to creo 3.
Unless i am being stupid I cannot rename parts in assembly mode only the active assembly.
Previously you where able to select individual parts in the assembly and rename in the assembly environment.
Now i have to open the individual parts and rename each file in part mode.
Am i missing something? this seems backwards from previous releases.
We don't use windchill or any other data management.
Dan
Ha simple?!
Thanks for the tip!
DanB
3 REPLIES 3
MartinHanak
(To:danb)
according to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS179098 this is current Creo 3.0 behaviour.
Alternate Solution in assembly mode:
  • File > Manage File > Rename
  • Click OK without changing the assembly name
  • Use the upcoming Assembly Rename dialog to rename individual components
MH
Martin Hanák
Ha simple?!
Thanks for the tip!
DanB
Dale_Rosema
(To:dbrowning)
Don't forget to mark it as answered if that worked.
