creo7 set customize ui for 2 diffrent departmant. and users
TP_10167633
Hello
i would like to have  2 different creo_parametric_customization.ui .
One for  department A
an one for department B
in department A i have also 4 user each of them have different  customization.ui .
We also have Windchill . So to change any PTC_WF_ROOT is impossibly.
Do you heave any idea  how to do that.
@TP_10167633 wrote:
The problem is that i need two *.ui file
One is basic and one is personal..
We have instalation on server and and local computer.
so you can use  creo_parametric_admin_customization.ui and creo_parametric_customization.ui
Please read https://www.ptc.com/en/support/article/CS288341
You can also start Creo using bat file and inside this bat file copy requested ui file into Creo.
Martin Hanák
StephenW
(To:TP_10167633)
I think what you want is a config option
load_ui_customization_run_dir YES
It loads your .ui file from your start-in directory based on your icon.
You can make 2 icons to start creo, one for dept A, one for dept B, Each start in there own start in directory.
I may be completely misunderstanding your question though.
Note:
If every user has its own computer with local Creo installations then every user can have its own creo_parametric_customization.ui file.
Martin Hanák
TP_10167633
(To:MartinHanak)
Martin Hanák
TP_10167633
(To:MartinHanak)
Yes i will try use but tha copy ui file .
Bu i must chek if allrady file exist that is overide each time when i start creo.
I hope that will also work whit WNC.
